Just opened 2 new packs of Xpres branded A4 paper to find a crease running down every sheet.
Immediate thoughts were that it could be damp but the crease is consistent, room is kept at a good temp all year around so I think it's unlikely. been through dozens of boxes and never seen this.
Anyone else ever had this?
Creases in sublimation paper
Re: Creases in sublimation paper
Ive had a similar problem with avery labels i found storing them in a a4 plastic box from new helped lots.
These have been in unopened boxes in plastic trays along with all sort of other paper types, labels etc.
Could be a manufacture error then. Have you contacted xpres?
I think it must be, bought through BMS. Definitely not damp, checked that. Not sure of the effect on a print yet, anything dense it may be an issue.
