Just got a swing press
Mossy88
Re: Just got a swing press
Post by Mossy88 »
Jeff;70187 wrote:Hmm, sounds like cheap quality...that can really be a pain in the a**, having to check the bolts everytime you use it...
It was a cheapy one, it was a few months before it come apart. i dont no if it was something i did.
Mike
tlworkwear
Post by tlworkwear »
Yup mine was a cheapy too from Ebay, get what you pay for at the end of the day but its doing the job it needs to for now and the way I see it is if it lasts a year then it has more than paid for itself..
Jeff
Post by Jeff »
Yup, if you plan to use it just now and then or just for one specific purpose, then screw the storage life. Otherwise, I would definitely recommend better quality.
Hey young world
rossdv8
Post by rossdv8 »
For my first shirts I just tried 200C for 40 seconds. You can't go too wrong. Buy some 100% polyester bed sheets and print on pieces to get temp, pressure and time sorted. If the bed sheet is a bit thin, stick something else under it to make it the same bulk as your shirts.
Much cheaper to cut up a $10 pair of sheets than waste 2 $5 tees.
SilentAlf
Post by SilentAlf »
Thank you all for your advice.
Does anyone know the best template size to use for coasters 95mm?
SilentAlf;70341 wrote:Thank you all for your advice.
...errr 95mm square! :)
Always make your templates a couple of mm larger so you can position the coaster easily, do around 97mm would be fine.
SilentAlf
Post by SilentAlf »
When printing onto t-shirts using the swing press what fabric does the T-shirt have to be? and where can you buy them from?
tlworkwear
SilentAlf;70715 wrote:When printing onto t-shirts using the swing press what fabric does the T-shirt have to be? and where can you buy them from?
You can press pretty much any fabric with the press mate, I mainly use cotton or a poly/cotton mix cause I mainly do vinyl but you can also use polyester for sublimation and even materials like spandex can be pressed. Hope this helps :)
SilentAlf
Post by SilentAlf »
That does help thank you. I think i need polyester as i will be using sublimation. do you know a supplier/wholsaler for polyester clothing?
tlworkwear
I normally use ralawise but there are also Pencarrie, BTC Activewear and I'm sure there are a couple of guys on here that sell Polyester tees :)
