Opencart - Product Mass Update Mod?
Re: Opencart - Product Mass Update Mod?
Looked at a few quick edit and mass edit mods but can't find anything to suit really.
Anyone any recommendations for v 1.5.5 ?
Could really do with something offline that shows all products and allows easy changes to weights and so on before being uploaded.
exportxml does this, download all products and details in a amazing spreadsheet, add/change etc then will change everything for you
costs about £40 but worth it
Do you have a link to this? I think this mod is worth buying, found a few today but thought I'd hold off for a recommendation
http://www.opencart.com/index.php?route ... =31&page=2
This looks ok but I'd sooner spend once and get it right
here is the link to the one i was talking about
this one is the most polished and you can edit anything from it
http://www.opencart.com/index.php?route ... load_id=31
Have you seen the free version?... might be worth testing before you buy an add-on.
http://www.opencart.com/index.php?route ... l%20export
Any idea if this works with latest version, 1.5.5.1? Only seems to go up to 1.5.3.1 in download list.arko;67766 wrote:Have you seen the free version?... might be worth testing before you buy an add-on.
Many thanks for the links31teg;67764 wrote:here is the link to the one i was talking about
This one looks ok, says you can get it cheaper on their site but it's been down for maintenance for last day or so. A few do seem a little more 'finished' and not so raw so I'll have a good look through them
Got that installed, can't for the life of me see how you do an initial export though.arko;67766 wrote:Have you seen the free version?... might be worth testing before you buy an add-on.
http://www.opencart.com/index.php?route=extension/extension/info&extension_id=17&filter_search=xml%20export
http://www.opencartmanager.com/
Came across this whilst searching, it's an offline management system. Appears to work very well. I can't decide it's it's really overcomplicated or not. I quickly made a few simple changes to products and updated my site so it can't be too bad! No idea on price, that could be a sticking point. This is a 180 day trial.
edit: Price may be around $149 and they do mass editors etc. but not cheap.
i went with the one as it seems well made, the support is great, and to be honest the price is irrelevant as it saves you that much time!
have a look on my opencart, its also got a html5 online case designer
www.wehaveany.com (currently still being heavily populated)
