Can you heat press onto painted wood?
PersonalizedGiftz
Re: Can you heat press onto painted wood?
Post by PersonalizedGiftz »
sorry if this is in the wrong place .. I have a heat press and am wondering if i can use the heat press to add words onto painted wooden plaques?
JMugs
Been thanked: 10 times
Post by JMugs »
I tried MDF ... not with success, some transfer, but very little.
You could purchase some digi coat and that MAY work.
I say MAY because it depends on if the digi coat will soak in to the wood which will depend on what you have painted it with.
Alternatively use a paint that contains chemicals similar to powder coat (if there is such a thing) and then use Magic Touch CPM which works really well on powder coated materials
PersonalizedGiftz
i have used a chalky emulsion
can you get polymer based paints?
I am not sure :-)
Social - is that a "no comment" ?! ;-)
logobear
Post by logobear »
CPM from magic touch works on most surfaces, ..... that can stand 140 or 150c.....
