MDP Flex vinyl peeling off
ladybug1802
Re: MDP Flex vinyl peeling off
Post by ladybug1802 »
Hi....I have printed a lot of things recently using MDP Flex vinyl printing onto Polyester...all seems to have worked well. But have had one client get back to me today about the fact that some of the lettering is starting to peel up.
Now I followed the guidelines of setting the heat press to 150 degrees C and pressing for 12 mins.....does anyone know what could have gone wrong?
Im hoping this is a one off and I dont get loads more people contact me!
viccar
Post by viccar »
did you pre press and also press afterwards to seal it?
Dave271069
Post by Dave271069 »
yep i had the same once, then i re-did it for the customer FOC but the second time i pressed it afterwards with some teflon sheet over the top, i still see the top now and its like the day i pressed it.
mrs maggot
Post by mrs maggot »
ask her what she washes with, a lot of people over use fabric conditioner, esp the really concentrated ones, and it plays havoc with material esp polyester - which might be why she is the only one with this issue
ladybug1802
viccar;66908 wrote:did you pre press and also press afterwards to seal it?
Pre press? As in press before i put letters on? if so no....i just pressed for 12 secs at 150°c .
Shes not washed it....its a dog vest and onky been used once
so what do u guys do....im a total beginner and just thought u pressed letters once... is that not the case?
viccar
Post by viccar »
You should realy pre press for about 5 seconds to get moisture out.
Then press the vinyl remove carrier sheet
Then cover with teflon sheet and press again for another 5 secs
ladybug1802
viccar;66919 wrote:You should realy pre press for about 5 seconds to get moisture out.
ah thank u! I had no idea! Where can i get teflon sheet?
viccar
Post by viccar »
you could get some baking paper for now,
it maybe worthwhile watching videos on you tube and reading up on how press vinyl properly, if you going to be selling items.
accdave
Post by accdave »
ladybug1802;66922 wrote:ah thank u! I had no idea! Where can i get teflon sheet?
The answer was in your first post :)
mrs maggot
teflon baking sheet are also fine, tesco and others sell them, remember with some flax - you must not pre press (123 flex) and others you do. i thought MDP put good instructions in with their products ? on their website, you really need to follow the instructions from your particular supplier as they all can differ slightly
