Epson Stylus WF7015 A3 +
Re: Epson Stylus WF7015 A3 +
I can get free delivery from BT Busness Direct for you but unfortunately their base price is higher than the one you found.
Hi
We currently own a A4 Ricoh SG 3110DN sub printer (hassle free thus far and producing great prints). However could you please advise if the ink costs are significantly more compared to say a A4 Epson printer. In addition, I am wanting a new A3 sub printer with good ink running costs and not sure what to buy. Thank you very much.
Hi welcome to the forum.
Maybe your qiestioon will get answered here but seeing as it is covering 3 points I would suggest posting it as a thread of its own and at the same time introducing yourself to everyone, not all members are guaranteed to read this thread.
WF-7015 acquired, some sub ink and blank cartridges ordered, let see whats gonna happen next.
Just a little feedback after some time and several dye sub. transfers
My equipment (amateur use)
epson 7015 (NO special color profile)
ink: Sublimation ink for epson printer from a chinese vendor.
Paper: truepix
medium: Rock slates
Heat press: generic swing away A4 Heat press
results: very good to perfect till now. Correct colors, smooth and even trasnfer. ofcourse there is always room for improvement.
Had only once a problem but i suspect what did go wrong (didn't let the print to dry before heat press it)
Only problem is the OEM cartridges that cause problem with ink flow, but now i have acquired a CISS το overcome this...
I will post a photo next time to see by your self
Paper: truepix
medium: Rock slates
would be interested to learn how things are going using this printer. already have the WF-7015 which i find to be a great printer but now have a heat press, so your findings would be most welcome. have found a uk supplier of the CISS equipment for this machine, which comes empty so would it be ok to fill with sublime inks?
Hi, first of all i am not a pro but just an enthusiast and everything i produce is for personal use and gifts.Ang;72383 wrote:would be interested to learn how things are going using this printer. already have the WF-7015 which i find to be a great printer but now have a heat press, so your findings would be most welcome. have found a uk supplier of the CISS equipment for this machine, which comes empty so would it be ok to fill with sublime inks?
The printer is being used as i commented above and for me its an absolutely perfect combination.
Only thing to take care is to have correct flow of the ink to the printheads.
hi pentaks - thanks for the answer. did you find it easy to attach the CISS system to the printer? and can i ask where you purchased the ink from. Many thanks
yes attaching the CISS is a 5 minutes task! about getting ink ask me privately, dont want to make an advertisment in public!
