Printer's installed (only took 2 calls to Listawood!!!) ;O)
Re: Printer's installed (only took 2 calls to Listawood!!!) ;O)
Viccar...they're 3mm and 4mm I think, so absolutely tiny....but they look great....going to stop printing now to try and cut a template...thank God my hubby's so patient!!!lol
3 and 4 mm Viccar, they look lovely....might have to have a wee play!!
What stencil material did you get? I use 2 and 3mm rhinestones.
Before you cut out all your design in the stencil material, just cut out a square of 4 holes, just to check you have right blade depth pressure ect. also you can check the hole with your rhinestone, to make sure its correct all before you use lots of expensive stencil material
What i do is cut the stencil material, then get a plastic tray, take the backing off stencil material stick on the tray and rip it off like a plaster should leave most if not all the holes empty.
Looking good Gayle & I bet you are rather impressed with it all now.
Stencil material Viccar?!?! Don't be silly...I'm Scottish....and I watched Paul's video about making your own....I've got some A4 cheap vinyl sheets, was going to double them up and make my own this time round!!!lol I have ordered the carrier tape though and a brush....hoping they might arrive tomorrow?!?!? Will follow your tips though for definite.
Thanks Ian...impressed!?!?! You're damn tooting!! I've had to 'walk away' from the computer so that I stopped printing!!
Love the mug! Is it a ready made template or your own design? I 'm looking for the Keep Calm template if there is such a thing!
Hi Twinsgran, thank you.....no this was my own design, but it isn't hard to do at all.....it's just getting the right font...you can buy the 'Keep Calm' font (it's not really, but it's as close as) but this was just one I had in my collection.....it's on one of my discs, I'll try and remember to get the name of it.
