Epson Printers with inbuilt Epson CISS
Re: Epson Printers with inbuilt Epson CISS
Just seen a post over on T-Shirt forums, and found out that Epson actually have their own CISS systems built into some of their printer models that are marketed in Asia regions...
They are named L100/L110/L200/L300/L800
Quick Google and found that this seems to be true:
http://www.ink-system.co.uk/all-in-one- ... -l800.html
Or on futher reading, it seems that these are new models, so UK availability may be in the pipeline. This on the heels of Epson bringing out a dedicated sublimation printer.
Ian M
Post by Ian M »
Thanks for that Tim. It looks good & wonder if the dedicted sublimation printer will be similar.
The dedicated sublimation printers are wide format models (44" and 64" IIRC), with large 1.5 litre bottle/carts things.
Ian M
Post by Ian M »
I've just been reading about these new printers from Epson & was wondering how Epson would stop people using 3rd party inks. Well, they have got some software where you have to put a code from each bottle of ink for it to reset. However I've seen there is now some free software to get around this so people can use 3rd party inks. The original Epson ink that comes with the printer is dye ink which is good news if you print things like photos. The CISS system is already conected & looks very neat & easy to fill too & it comes empty when new.
Ian M
Post by Ian M »
pisquee;59973 wrote:The dedicated sublimation printers are wide format models (44" and 64" IIRC), with large 1.5 litre bottle/carts things.
Tim, no doubt that will be beacause of the Sawgrass patent on dye sub desktops but, is this Epson gearing up for when the patent comes to an end. Seeing what I've just seen & read it would be easy to use one of the desktop models for sublimation if you get a colour profile made.
I'm quite tempted to import a few to flog on, but I would then be responsible for warranty-ing them, which kinda puts me off!
carter2
Post by carter2 »
These printers are helpfil in shaing Hi-Definition all-in-one from any room in your home with built-in Wi-Fi. Produce photos and automatically print double-sided documents too. Integrated wireless and Ethernet for shared printing and scanning
mrs maggot
Post by mrs maggot »
carter - do you just google a few facts from the printer and then post them ?? i am wondering if you are some kind of printer spambot ???
or trying to get his post count up for some reason
