I know there are 100's of ready made templates out there for sublimation items but sometimes a template isn't available or cannot be found.
If you have a scanner, and if the item is flat(ish) then place it in the scanner with something dark over it like a black t-shirt.
Scan it at true scale (usually 300dpi in photoshop) to give you a prefect 'to scale' scan of the item which you can then use to make sure your image will cover the item (and also delete some of the printing area if it's not required to save ink).
Hope that helps someone
