Brother printer unusable print quality
WorthDoingRight
Re: Brother printer unusable print quality
Post by WorthDoingRight »
Well Ian M I at least tried to keep my replies polite, your replies seem to be coming straight out of where an air balance plug would fit nicely!
bigj2552
Post by bigj2552 »
Ian M;55283 wrote:
All you will do is confuse someone who is new which is probably what you are doing already.
i agree here....keep it simple for new folks starting into this....to many la-de-da words and folks get confused.
this business is awkward enough to learn without overcomplicating it for others :rolleyes:
SIMPLES...and not the meerkat version !
WorthDoingRight
@bigj2552 How is my initial comment 'they do supply little flying saucer shaped funnels that are designed to be left in the holes' overcomplicating matters? I said what they looked like, where they went and what they did!
Whatever you call them the description should have been enough for them to be recognised and used.
bigj2552
Post by bigj2552 »
WorthDoingRight;55293 wrote:@bigj2552 How is my initial comment 'they do supply little flying saucer shaped funnels that are designed to be left in the holes' overcomplicating matters? I said what they looked like, where they went and what they did!
sorry bud - but your whole demeanor sometimes comes over as "overcomplicating" things just a tad when its really not needed...not for the sake of the regulars, for the new folks coming in......
and i,m NOT just referring to this post - others posts as well bud....
suggestion for you my forum friend - have a long hot coffee and chill back a bit...trust me, you will get on a lot better and make MORE friends :wink:..listen to the ol man :wink:
johnny
WorthDoingRight
Well, your comments are noted and I will go back to my cold cup of coffee and get on with some productive work for my own benefit and leave helping to others. I might be seen as nit-picking but I come from a family with a long history of working on cutting edge engineering projects and believing in the ethos of 'worth doing right' and sometimes that gets the better of me when answering on here.
Ian M
Post by Ian M »
WorthDoingRight;55290 wrote:Well Ian M I at least tried to keep my replies polite, your replies seem to be coming straight out of where an air balance plug would fit nicely!
What isn't polite about my replies? All I have done it stated the facts & even added a bit of science in there too. The problem we do seem to have here is that someone is wrong who will not admit they are wrong. I'm not the only person who has tried to put you right on this & explain what is the correct name for something. If for example I needed some new CISS Air Filters I wouldn't search on the internet for 'flying saucer shaped thingy's' would I. That is the reason why we do like to use the correct name for something.
Ian M
Post by Ian M »
I would suggest you report me to admin.
WorthDoingRight
Ian M;55308 wrote:I would suggest you report me to admin.
LOL I am sure if admin had any issues they would let us both know :biggrin:
I did not say that they were not called filters, I just made the comment that as supplied they were not capable of filtering anything! If someone had said to me where are the filters that were supplied with your refillable cartridges, I would have answered, no filters were supplied but there were some weird flying saucer shapedbits of plastic :rolleyes: Remember 'Today, if you are not confused, you are just not thinking clearly'.
Craig
Post by Craig »
I think you need to agreed to disagree and move on and keep the forum and keep smiling :biggrin:
JSR
Post by JSR »
WorthDoingRight;55214 wrote:Well they are filters imho only if they have filter material in them. If when they arrive they have no filter material then they are little funnels lol
I'm probably setting the cat well and truly amongst the pigeons here, but my "little flying saucer shaped funnel" things have a thin white mesh disc in the middle of them, which looks like a filter. I always thought of them as filters because they have a filter in them.
I didn't know anyone supplied them with the filter missing. That said, some have been known to separate into two halves in the shipping bag, so it's possible the filter material could have fallen out.
