Help and advice
Any OS, software in here.
jennywren
Re: Help and advice
Post by jennywren »
I have a lot of cdr images that I need to open in photo shop or turn them in to a jpg, is this possible and which software would I need to use. Your help you is need as I've seem to run out of options.
JackB
Re: Help and advice
Post by JackB »
Try File - import in photoshop.
Jack
Re: Help and advice
Are you looking for a program that will change the format for you? I.e point to directory and do a mass change?
jennywren
Re: Help and advice
Post by jennywren »
JackB;54873 wrote:Try File - import in photoshop.
Jack
It won't let me, frustrating
Re: Help and advice
if they are CDR then this is corel file format. open them in corel and export to JPG or ideally to EPS. then they can be opend in PS.
jennywren
Re: Help and advice
Post by jennywren »
Justin;54875 wrote:Are you looking for a program that will change the format for you? I.e point to directory and do a mass change?
I need a one folder change with 30 images, but not the rest of my images
Re: Help and advice
Have you got corel Jenny?
jennywren
Re: Help and advice
Post by jennywren »
I have but on the lap top at home. I'll do it tonight, thanks for your input everybody. To be honest I don't know my way around cdr like I do photo shop more the pity
Re: Help and advice
Really easy Jennywren
Open the file in Coreldraw
Hit "CTRL" + E (Or goto "file" and scroll down to "export")
Top part of the window that opens is a standard windows box.
At the bottom you have three options
FILENAME (Which is self explanatory)
SAVE AS FILE TYPE (which you can select whatever works best for you (I recommend EPS)
Sort type Should read default
Click on the button in the bottom right that says EXPORT
A new dialogue box will pop up which should be set to the correct settings. I have attached a picture which shows you these standard settings. Clicking on the advanced tab gives you other settings but you should not need to touch them
[ATTACH=CONFIG]1208[/ATTACH]
vB_ID:1208
vB_ID:1208
Re: Help and advice
Try Googling batch convert cdr to jpg or similar. Iv e done this with other formats, not 100% sure if you can do it with cdr though.
