Hi All,
I am totally new to this forum and to sublimation printing, i would appreciate all the help i can get. i have an 8 in1 press from Coralgraph (paper from them aswell) and my printer is an Epson B1100, my ink is Fotorite CISS. i have tried to print on a mug (bought from Signzworld on Ebay) and i have had no luck, no image will transfer onto the mug. The instruction that came with the press are useless and the timing seem much higher (300-500s) than what i have read on the forum so far. I have tried temp:180 and time:180s with still no luck, instead the mug has gone dull in colour. Can anyone please help me as i am really confused about where i may be going wrong. Another question i have is: Can the same mug be re-used until i get the hang of things to avoid waste of new mugs? Any help is very much appreciated. Thanks.
hello to all hope someone can share some advice as im new to this. thx
Re: hello to all hope someone can share some advice as im new to this. thx
are you using sublimation inks
I suspect your main problem lies here, whats sort of ink is it ?wowp4u;48340 wrote: my ink is Fotorite CISS. .
dont blame the press. blame your inks
They are fantastic to print photos but unfortunately not on the mugs
You are going to need to get sublimation inks for the B1100. The Artainium Easyflow system comes with 5x100ml of inks and RRP of this is around £239 +vat. Oh ...and welcomewowp4u;48340 wrote:Hi All,
- Has thanked: 13 times
- Been thanked: 12 times
Hi and welcome to the forum
Not much I can add to the above, other than the fact that I found that paper useless as well
Hi
Thank you to all for the advice. I will look into getting the correct inks and try again...
And its great to be a part of this forum, everyone has been very helpful and im confident that i can ask for help and there is always support here. Thank You
