opencart !
Any OS, software in here.
bassqee
Re: opencart !
Post by bassqee »
when a client uploads an image - where does it go?
smitch6
Re: opencart !
Post by smitch6 »
you can either log-in to cpanel to collect it or if you have vqmod installed there is a mod which allows direct access from admin panel
JSR
Re: opencart !
Post by JSR »
bassqee;45262 wrote:when a client uploads an image - where does it go?
Login to the admin of your OpenCart and click "View" to view the order that you're working on. On the "Orders" panel, click the "Products" tab and you'll see a list of products ordered by the customer. You should also see something like "Upload Image: .jpg" underneath the related product. The image name should be a clickable link which you can click to download.
If the customer has ordered other items, just do the same for the other images.
smitch6
Re: opencart !
Post by smitch6 »
that only works if you have the VQMod installed btw :)
JSR
Re: opencart !
Post by JSR »
smitch6;45276 wrote:that only works if you have the VQMod installed btw :)
I don't have the vqmod installed.
bassqee
Re: opencart !
Post by bassqee »
JSR;45274 wrote:Login to the admin of your OpenCart and click "View" to view the order that you're working on. On the "Orders" panel, click the "Products" tab and you'll see a list of products ordered by the customer. You should also see something like "Upload Image: .jpg" underneath the related product. The image name should be a clickable link which you can click to download.
that works for me - no mod installed.
smitch6
Re: opencart !
Post by smitch6 »
they must of sorted it on that version then :)
JSR
Re: opencart !
Post by JSR »
smitch6;45279 wrote:they must of sorted it on that version then :)
I'm using version 1.5.1.3 on my live site and I'm working on 1.5.2.1 on a copy of that while doing the upgrade. Both are okay with the image link in the back-end. I've never used an older version of OpenCart, though.
bigj2552
Re: opencart !
Post by bigj2552 »
JSR;45280 wrote:I'm using version 1.5.1.3 on my live site and I'm working on 1.5.2.1 on a copy of that while doing the upgrade. Both are okay with the image link in the back-end. I've never used an older version of OpenCart, though.
also confirm that the above way works fine with 1.5.1.3 :biggrin:
Mattie
Re: opencart !
Post by Mattie »
Works fine for me on 1.5.1 also
Matthew
