Changing paper size
Re: Changing paper size
I belive its under printer and faxes. You can see virtual printer instaled and colled power driver. But i am not sure for 100%
North guy
Post by North guy »
cheers guys, your legends!
does anyone know why my cups would fade a little as it gets near the mug handle?
Coz there is.less heat on the heat blanket. Some press camt get close enough to the handlea.
John G
Post by John G »
Not another one :confused: its MUGS :biggrin:
North guy
Post by North guy »
so it just a matter of trimming ends off?
sorry John MUGS lol
AJLA
Post by AJLA »
Yes or just make your image smaller, I have two types of machine here one the wraps ge quite close to the handle and the other no where near. Also watch the top and bottom of the mug as this can happen here too particulary if they are not really straight.
JackB
Post by JackB »
North guy;40881 wrote:hi , yes i am using power driver, where is the virtual printer driver tab?
Cheers
Start, Control panel, Right click on your Ricoh printer and select Printing Preferences, the powerdriver preferences panel will open, and along the top tabs you will see virtual printer driver.
Jack.
North guy
Post by North guy »
AJLA;40890 wrote:Yes or just make your image smaller, I have two types of machine here one the wraps ge quite close to the handle and the other no where near. Also watch the top and bottom of the mug as this can happen here too particulary if they are not really straight.
hmmm this could be my problem then.
what width would you suggest? i currently use 23.8
John G
Post by John G »
There's no way I could use 23.8 - I made it easier for myself and took it in, along with a few mm top and bottom.
North guy
Post by North guy »
what ya mean John?
Users browsing this forum: Bing [Bot] and 0 guests
