Metal Mugs
photoscape
Re: Metal Mugs
Post by photoscape »
i know these have an official name but cant remember what it is, basically i was wondering if anyone knows a supplier of the enamel tin cups and if they can be sublimated on. basically im a steam rail photographer and the white enamel cups with a blue rim are a railway thing and if i can find a supplier im hoping my contact in a big musuem will buy them lol
Andrew
Re: Metal Mugs
Post by Andrew »
I have someone who has been asking for these as well. I've been looking for a blanks importer and to then get them coated myself. No luck so far.
photoscape
Re: Metal Mugs
http://www.johnlewis.com/160892/Style.aspx?source=63258
thats an example of the type of mug i want to put photos on
Andrew
Re: Metal Mugs
Post by Andrew »
Yep, that's the one I want as well. Time to look for an importer of them I guess so I can try one under the heat of printing. How many are you after?
bikertec
Re: Metal Mugs
Post by bikertec »
I believe you can buy a coating that will allow this. Ask bms he's the man you need.
Ride it like you stole it shiny side up.
Re: Metal Mugs
bikertec;18303 wrote:I believe you can buy a coating that will allow this. Ask bms he's the man you need.
Thanks for the recommendation, but we don't stock/ sell a coating for self coating.
Re: Metal Mugs
They wouldn't need to be coated if you used TMT CPM6.2 transfer papers - with the use of a laser printer you can print onto uncoated products.
Andrew
Re: Metal Mugs
Post by Andrew »
Never been keen on the tmt options. They look slow and often work out costly. If I get a batch coated then they could just be the same cost as printing a standard mug. I'm not a big fan of tmt as a company so might not have given the process enough of a chance.
Re: Metal Mugs
i found on ebay some metal ones but diferent.
LINK
photoscape
Re: Metal Mugs
Ive used that ebayer before seems to like sourcing new products, had some good stuff off him in the past
