This should help me!
Discuss anything to do with Screen Printing.
GoldRapt
Has thanked: 5 times
Been thanked: 7 times
Re: This should help me!
Post by GoldRapt »
I'd be like a kid in a sweet shop with all that gear.
regards
Tony
-launching july/august 2026
Flash
Post by Flash »
Nice kit John 8)
Looks like you have a little more space than me!
I've got even less space now as the new Thermograph machine (Transfer dryer) turned up today. It was sent beautifully packaged and with a full VAT receipt.
I didn't have a lot of time to 'play' before closing the shop but long enough to fire her up! All works fine but the rubber drive-belt for the conveyor is a little perrished so will need replacing soon, looks very similar to one off an old Hover Junior :idea:
Otherwise it appears that by showing it a rag will make it look a little better 8)
Can't wait to run my first batch of Transfers through it and get the settings right.
Onwards & upwards.
Phil
Life is like a jigsaw puzzle........i'm sure i'm missing some pieces!
John G
Post by John G »
Spot on - its nice when things turn out better than whats expected.
About space - i've got none left. 6 months ago I moved from a 1700sqft unit to a 527sqft unit. Everythings shoehorned in and my other dryer and carousel are in my garage. :D Still managed to fit 2 full size washout booths, a 30 x 40 hand bench with racks, and a pad printer into the new unit though. :D
Flash
Post by Flash »
John G wrote:Spot on - its nice when things turn out better than whats expected.
I've got a spare drying rack here John, if you want it for your garage ;)
Phil
John G
Post by John G »
Already got a spare set of racks in the garage too! With all the kit in there I could be running a second print shop. Image
GoldRapt
Post by GoldRapt »
Flash wrote:Stole this baby off Feebay today...........
This will save me a HUGE amount of time curing my screenprinted Plastisol Transfers for T-shirts! I was using a Heat-Gun!
Phil
I just realised, That's a Caslon Thermograph without the metal shielding on it.
If you can refit the metal shielding your operational costs should go down.
regards
Tony
Flash
Post by Flash »
GoldRapt wrote:I just realised, That's a Caslon Thermograph without the metal shielding on it.
Hi GoldRapt,
I don't think this is actually a 'Caslon' machine it has got a manufaturers sticker on it but off the top of my head cannot remember their name, I think they are from Cornwall.
Metal shielding Image Where does that go on the machine :?: And how will it affect the opperational costs :?:
Ran my first batch of Transfers through today, the belt is slipping a tad due to the problems mentioned above but superb Image what a labour saver. No problems with the paper curling either, my theory proved correct 8)
Phil
GoldRapt
Post by GoldRapt »
Flash wrote: Hi GoldRapt,
Phil
http://www.caslon.co.uk/Thermography_Machine_Offline_Leaflet_2008.pdf
Its about heat entrapment, getting up to temp quicker saves you dosh the shileding would help achieve that I think.
regards
Tony
