L1800 Converted DTF Printer
Re: L1800 Converted DTF Printer
I'm selling my hardly used L1800 DTF Printer, not long after buying and converting this I moved to a wide format DTF, so its been sat with extra dampers installed and filled with cleaning solution. It's actually had very little use it was purchased as a backup for another L1800 DTF printer but subsequently put into a storage state after I moved over to wide format DTF so now it's surplus to requirements.
I purchased it new and converted it so it comes with external waste ink tank, rollers removed ( other than each side to help the media to feed) and also I made an access to the side to enable locking/unlocking of the print head with a screwdriver for wet capping and maintenence.
Due to work commitments I'm not in a positon to be able to teach you about these printers and DTF printing so only purchase this if you know what you're doing and are willing to undertake the daily maintainence required, in addition to this printer you will need DTF Rip software ( acrorip or similiar) and your own inks and media. I can put the purchaser in contact with my suppliers for all of these and possibly supply some with the printer.
SOLD
SOLD
Hi Jason
Hope you are well fella
Do you know where to purchase the curing oven and the powder tray? Don't know much about DTF (or sublimation some might argue
) but thought that you need both of these items as well.
Hi Mate,
I'm good thanks and hope you are too, you can cure them in your mug oven, we do ours this way or use our screen print belt dryer, powder tray if you need one can be anything a tupperware tray or cardboard box whatever suits.
Let me know if you have any more questions
cheers
Jason
cheers
Jason
Just a couple
I have Acrorip which I purchased off some dodgy looking bloke when I purchased his UV printer... Will this run a DTF? I presume it will but just checking there are no plugins or different versions of the same software,
Secondly, how long did it take you to master the powder application? Am I overthinking that this is the key part to get spot on and is the tricky part to master
Lastly, how long does curing take and how accurate does the oven need to be etc etc. For example, assuming I have seperate shelves, could I put 20 odd sheets in there for XX minutes and all be perfect or is it the same as sublimation in an oven that occasionally you will get failures.
I know the fella, and he is dodgy
Its Acrorip 9.0.3 I'm not sure if the UV version is the same as the DTG/DTF version.
There's no skill to powdering you're just applying adhesive powder to wet ink, you just need to make sure the whole area exactly the same as screen print transfers, even you can manage this
Curing isn't particulary tempramental you're just melting the adhesive into the print, our oven is set around 130 for 2 - 3 minutes some people without an oven just hover the press over the print until it's melted, you could even use your griddle. We don't really get any failures other than sticking our fingers in the wet ink before its cured which obviously means the prints no good.
A very large part of our printing is now done DTF, I've sold my DTG in favour of it.
- Has thanked: 13 times
- Been thanked: 12 times
Ok, enough about the dodgy fella...we all know who he is and he's just about to replace the word 'dodgy' with 'fine'
I've seen the results of this and can honestly say it is superb. I was very surprised how easy it was to apply the powder, even Jason makes it look easy with his webbed fingers so you should be fine Simon in your sheep wellies.....
I've seen the same printer for sale on another site for £750-£800 but it was absolutely ditched so this is a great price for something almost unused.
HI Jason , How good these DTF prints are comparing with DTG ?. I have a Epson F2100 and I heard you can use it to do DTF as well ?. . I would like a DTF as DTF transfers gives you more freedom when you are pressing them in to .Who do you recomend to go for the addhisives and films in UK ?. ThanksJason;149386 wrote:I know the fella, and he is dodgy
There's no skill to powdering you're just applying adhesive powder to wet ink, you just need to make sure the whole area exactly the same as screen print transfers, even you can manage this![]()
Hi, In my experience it's better than DTG, no need to pretreat for darks, you can decorate a lot more materials and if a print messes up, it's only the media thats no good and not the garment like DTG.
The downside compared to DTG is that you can't print a soft edge like DTG although there are ways around this.
Yes you can do DTF with a DTG printer, you'll need to change to DTF inks so I would speak with your Epson supplier to see which inks and media they recommend for your machine.
SubOnCotton
Some info on DTF with F2100: https://www.jbsewing.com/en/dtf-printing-3Ravisteam;149445 wrote:HI Jason , How good these DTF prints are comparing with DTG ?. I have a Epson F2100 and I heard you can use it to do DTF as well ?. . I would like a DTF as DTF transfers gives you more freedom when you are pressing them in to .Who do you recomend to go for the addhisives and films in UK ?. Thanks
Would someone with experience of both, say that DTG is better for light cotton garments and DTF better for darks?
