I think this is the issue. Would profiling help limit the ink density or is it as simple as using the colour density slider within the Epson driver?pisquee;148268 wrote:If the ink is too much for the InkTec paper then you need to lower the amount of ink you are using.
The colours when pressed are excellent but it it does appear to be very fussy when it comes to the amount of ink placed on the paper, No other paper I have tested so far has an issue with the density of ink.
