What I am saying is that I believe Catalina has introduced an ICC problem. I use Mojave which is absolutely fine
Paul;146080 wrote:So how do you use your Icc on Mac? What software do you use to print from?
Got to Library > Colorsync > Profiles and see if you have any there. If you do, your mac is using them. Don't forget any printer you use. Comes with drivers and that's what is using icc profiles.
So please check in your printing software if you can set them.
