Badge machines and cutters
cook_58
Re: Badge machines and cutters
Post by cook_58 »
Hey everyone
I hope this is in the right section, cant really find a section for this topic. Admin please move if there is one.
Anyways.
I recently purchased a cheap 32mm Chinese badge machine. Just to start myself off doing pins for friends bands etc. Its not the greatest of machines and I am assuming the badge parts I got with it arent the best either, but I have nothing to base that off of though.
The finished product isnt amazing but is passable and I get a failure rate of about 20-25%
I'm looking to upgrade now, and move on to doing bottle openers as well as stick to 32mm maybe 38mm pins etc.
I've looked at machines from badgematic their flexi machine. Blank badge, their G series, digi print and a couple others.
I'm just curious if people out their have these or use different kinds and what the finish is like, what their ease of use is and if they work spot on with a real low failure rate to them, as well as what the badge parts are like for working with.
Obviously the cost of accessories for them is a factor as badgmatic and blank badge etc. Have different prices for stock.
I use a laser printer and have been trying different papers as well, so I know some of that will effect how the pins will come out the machine I use as well.
The other thing is cutters, some are nearly as expensive as the machines, so is it worth Investing in the expensive ones as compared to the middle of the road ones. Do they last longer, speed up the cutting process?
I tend to do up to 100 badges per band when taking an order from them. Which with the crap Chinese cutter that came with the machine takes up most of my time and does my head in as its rubbish!
Thanks in advance for any advice/replies. Just hope I've not waffled to much! [emoji85][emoji23]
Sent from my SM-N960F using Tapatalk
Ian M
Post by Ian M »
I get all my badge making supplies & equipment from e-badges & never had a problem. I hope it helps you https://www.e-badges.net/
When I made badges I used a contour cutter (Cameo, and later a Silver Bullet) to accurately cut many circles in one go from designs printed in my Canon printer.
G Series all the way. We make a lot of 75mm magnets and this press takes a lot of hammering and performs perfectly.
G series for me too!
vB_ID:5672
vB_ID:5672
cook_58
Post by cook_58 »
What about cutters what do you guys use?
I use this.Image
cook_58
Post by cook_58 »
Awesome, thanks
wayupnorth
Post by wayupnorth »
I use an interchangeable die tool from badgematic (Germany) as well as 2 fixed die presses from blankbadge (UK). Not all sizes and styles available from one supplier (at the time) hence using two. For cutters I have two lever types which are expensive but easy/comfortable to operate. I also use a brother scan n cut occasionally and badgematic supply precut blanks on an a4 sheet for laser printing. Quality is very good and once the page margins are adjusted for your printer they work really well and low cost. One thing to note is that some badge sizes are not universal and 1mm bigger will prevent a successful press so probably best to buy the cutter from the same supplier as your blanks..
vB_ID:5674
vB_ID:5674
One thing to note is that some badge sizes are not universal and 1mm bigger will prevent a successful press...
That's why I prefer to use my cutting machine, even though I already have a circle cutter that I received with my badge press.
