questions for photo buffs
Re: questions for photo buffs
Does any one know how to shirk a mask in photo shop. I have looked at as many photo shops help for hours, maybe I'm using the wrong word shrink, I need to make the mask smaller than the original picture, can anybody help.
do you mean "reduce"?
If so, use the mask selection tool and right click inside the selection, then choose "transform selection" you can then transform as you would normally.
Hope that helps...
Dave.
Hope that helps...
Dave.
Not sure what you mean i have four images to a4 do I transform the a4 sheet,, did it but then the images did not line up , as i got one in line the other three was off, I expect the answer there in front of me but can't see it because I ready to heave the laptop through the window, Sorry can you try to explain to me again
The wow is good but this bit is doing my head in.
Jenny, if you do as Dave says but press Ctrl & T keys which is shortcut to the transform tool.chongsta wrote:do you mean "reduce"?
Hope that helps...
Dave.
Hope this helps.
Ian
I using a previous a practize sheet when trying to figure out wow, i did 4 images then the mask, I followed the instructions as required for pressing the wow. do you think because I using a practice sheet is the reason it won't work, I have tried I think I just a pillock, by section
do you mean inside the image.
Could any please so kind to send the instructions on how to a mask and how to shrink it, I feel as though I have done something wrong somewhere, so I I think maybe the best thing is for me to go straight back to the be the beginning and start as though I know nothing, and going by this post I don't, I tried for three ;hours last night trying to figure it out and have to start fresh with this. Can someone please help me, I would truly appreciated it. I seem to have forgotten everything I've known. Mind melt they call it.
I think it would be helpfull if you post picture you want to reszie.
I would do step-by-step for you but i dont know what you mean by mask for wow paper as I never done it before
I think you'll need to do these individually otherwise you'll also shrink the space between the images which will prevent them from lining up.four images to a4 do I transform the a4 sheet
Users browsing this forum: Amazon [Bot] and 9 guests
