Graphtec Corel Plug In - Anyone using?
kermit
Re: Graphtec Corel Plug In - Anyone using?
Post by kermit »
Hi Justin, I had this issue after the last CM3 update. I reverted back to the previous one & it's been fine since.
Keith
Stitch Up
Post by Stitch Up »
I've had this same problem with CM3 and discovered that making sure CM3 (or any parts of it) are NOT running when you send the job.
Although you can view the design in wire-frame in Coreldraw, are you certain the the properties of the outline object are set to hairline? I'm sure we've experienced similar issues.
Email the design to me and I'll check it cuts on our CE5000.
John
Online
CD8 isn't supported it appears but 4 should be, will revisit this again soon.
Stitch Up
Post by Stitch Up »
We're using CD6 without any issues.
