Hi
Could not find the answer anywhere, I have a Ricoh 3110 printer which I intend to use for a sublimation business I am about to start. I bought the refillable cartridges for it and sublimation ink but have just found out some disavantages of using sublimation ink: 1: polyester tees are more expensive then cotton tee, 2: sublimation can only be done in light color tees and I would like to sell black tees also; I was told that if I use Dye based ink instead of sublimation ink I can transfer to cotton and also datk color tees; The problem is i cannot find dye based ink for Ricoh printers, I found many for epson but not for ricoh. Could anyone enlight me or tell me where I can get dye based ink for my ricoh 3110? Many thanks
Dye based ink in Ricoh 3110
mags1892
Re: Dye based ink in Ricoh 3110
You need PIGMENT ink not dye for best print quality std ricoh ink is pigment.
Thanks, I have refillable cartridges once my original ricoh ink is finished will I find the pigment or dyebased ink to fill my refillable cartridges? The ones I found on internet says they are for epson only.
mags1892
Buy Ricoh OEM carts loads on ebay fom people who use Ricoh for sublimation.
How are you intending getting the images onto the tees?
I think you have 2 similar threads running consecutively discussing this, might want to look at that
