Slates
Mugshots
Re: Slates
Post by Mugshots »
Hi all,
im following the time and temp instructions off the site where a I bought my slates down to a t. Problem I'm having is where the tapes been holding the image on, upon removal of the paper the tape is leaving marks on the image on the slate.
any ideas?
Re: Slates
Mugshots;107453 wrote:Hi all,
any ideas?
When we've printed these we cover the whole slate with the paper and use tape to hold the paper on by sticking it on the back of the slate to the paper.
Re: Slates
Isopropyl alcohol takes the marks straight off whilst slate is still hot. Assuming you're taping to the back?
scotty44
Re: Slates
Post by scotty44 »
As said, use a full A4 sheet, centre image then you can wrap the paper around and tape on the back :)
Mugshots
Re: Slates
Post by Mugshots »
Its the tape on the image. I put the paper with the image on the slate then put the tape on the image paper then pull it onto the back of the slate. The tape marks are coming onto the image itself.
wayupnorth
Re: Slates
Post by wayupnorth »
No need to put the tape anywhere near the image:
vB_ID:3788
vB_ID:3788
vB_ID:3788
vB_ID:3788
vB_ID:3787
vB_ID:3787
scotty44
Re: Slates
Post by scotty44 »
Why do you need to put tape onto the image:confused:
I have just done a few so took a picture of mine!
vB_ID:3789
vB_ID:3789
2015-12-20 17.58.48.jpg (97 KiB) Viewed 247 times
Mugshots
Re: Slates
Post by Mugshots »
Ah yes. I understand now. Im not leaving enough blank paper round the edge! Nice one. Thanks very much
Mugshots
Re: Slates
Post by Mugshots »
Ok. Sorted that. Next problem is what I can only describe as matt "dry" patches. I do 495 sec at 190.
Any ideas whats wrong?
scotty44
Re: Slates
Post by scotty44 »
Are you pre heating the slate before pressing? They hold moisture.... I use plain paper over the slate and drop the press Down to rest on it for about 45 seconds.... you will see the moisture on the paper when you lift it up...
