Clip art Problems!!
Re: Clip art Problems!!
Hi there.
Everytime i print out a clip art image it prints out with a dull box around it.....looks terrible when applied to mugs.
Im using Coreldraw 12 with an icc profile.
Can anyone shed any light on this?
Im printing mugs for companies using there logos which are in jpeg format.
Ive tried the magic wand thing but still prints out with that dullish box in back ground.
Please help me
best regards
Michael-Watch Designs
Please help me
best regards
Brixhamboy
Hi Michael, what type of images are you using? 'Clipart' is a generic term which does not describe the image well. If you look at the image title it will end with '.jpg' or '.png' etc. Do you get this problem with a particular type of image? It is difficult to give a precise answer and avoid speculation without knowing a little more about what it is you are dealing with.
When you describe this dull box do you mean an outline stroke or the whole box filled with a feint tone. Do you have an example to show?
I am sure this forum will provide sound solutions for you.
Im using jpegs.
When workin with image it is not on the screen. Just when i print um out its there behind image
[ATTACH=CONFIG]3738[/ATTACH]
I know its a bad puc but if you look at left hand corner of image y can just see it
- vB_ID:3738
- 20151103_105533.jpg (93.74 KiB) Viewed 618 times
If you are printing these for this company they should be able to provide you with an actual graphic file, ai CDR or even a PDF would be better than an images taken from the web.
i belive this issue is now sorted?
Cheers Paul, for some reason I am not getting all " New Posts" when they are new only showing up in " [CENTER]The threads below have not been updated since your last visit but still contain unread posts."Paul;106032 wrote:i belive this issue is now sorted?
[/CENTER]I didn't notice the timeline either.
I that directed at me or the original question? If the original question, I would like to know how it was solved as well.Justin;106036 wrote:What was causing the problem?
- mrs maggot
maybe its a secret only Paul and Michael know ???
