Premium Membership available at just £10 per year.....Discounts with Ink Express...Listawood...Xpres and more!
User Tag List
Similar Threads
  1. Black printing "faint" - coming out brown when pressed
    By Pea in forum Printing Problems/Issues
    Last Post: 08-06-2015, 07:14 PM
  2. Blacks coming out brown.
    By Earl Smith in forum General Dye-Sub Chit Chat
    Last Post: 05-12-2014, 02:15 PM
  3. Replies: 7
    Last Post: 22-09-2014, 08:18 PM
  4. Black mug printing shows brown
    By RoyLittle0 in forum Printing Problems/Issues
    Last Post: 08-08-2014, 04:19 AM
  5. Greys coming out brown?
    By Lorcan in forum Printing Problems/Issues
    Last Post: 11-06-2010, 05:14 PM
Results 1 to 10 of 10
  1. #1
    Junior Member
    Join Date
    Sep 2010
    Location
    Manchester
    Posts
    7
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    black ink coming out brown
    Hi Everybody,
    I've just taken delivery of the following kit rom BMS:
    Ricoh GXe3300N printer
    DF1 mug press
    TRUPIX paper
    BMS European mugs
    Each time I've tried a mug the black tends to come out brown. I'm using the heat/time settings as advised by BMS. Am also using the Powerdriver software.
    What am I doing wrong?
    Bit worried as I'm going to an sales assignment on Wednesday where I'm going to take quite a few orders!
    Any help would be very much appreciated.
    Chris
  2. #2
    Administrator Mini KickUps Champion Justin's Avatar
    Join Date
    Sep 2009
    Location
    Shetland
    Posts
    8,925
    Downloads
    6
    Uploads
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: black ink coming out brown
    HI Chris and welcome to the forum ;)
    What time and temp are you using with the DF1? What software are you printing through and are there any other profiles being used in there?
    There have been a few posts in the past regarding colours turning brown so may be worth a quick search for some more help. Drop Martin a line (if he doesn't respond on here first :D )
    I'll move this post into printing problems as it's better suited there.
  3. #3
    Junior Member
    Join Date
    Sep 2010
    Location
    Manchester
    Posts
    7
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Justin,
    Thanks for the very quick response.
    BMS instructions tell me to set idle temp. at 110 and operating temp. at 180 - which I've done, and to press for 150 seconds.
    I'm not using any profiles (to be honest, not sure what a profile is, but can't find any mention of it in the powerdriver settings.)
    I've imported the jpg file into Microsoft Publisher to position it and then just printed it, selecting the Powerdrive printer driver.
    I telephoned Scott at BMS to check the substrate setting in the printer driver as it defaults to 'unisub products' - I asked if it should be change to 'ceramic' - he got back to me after speaking to Sawgrass and they told him it was not required to change the setting.
    Hope this sheds some light on things.
    Chris
  4. #4
    Join Date
    Sep 2009
    Location
    Shetland
    Posts
    8,925
    Downloads
    6
    Uploads
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Chris, try pressing for 180 secs, this seems to be a better compromise. What temp is the press at when you print? Not sure about printing through Publisher, not something I've ever done, I always use CorelDraw, Photoshop is the other normal weapon of choice.
    Unless I'm mistaken, Powerdriver is instead of a profile so you should be ok there.
    Do you have any other software you could use? Certainly increase your time, I use 185c for 190 seconds.
  5. #5
    Senior Member bms's Avatar
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,593
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't increase your time! The browning of blacks occurs because your printing too long at too hot a temp. The SubliJetR inks can brown if pressed too hot unike the Artainium. I'd suggest the following: 110 idle, 170 temp and 120 seconds for the Ricoh printers using the Powerdriver software.
  6. #6
    Join Date
    Sep 2009
    Location
    Shetland
    Posts
    8,925
    Downloads
    6
    Uploads
    1
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So SubliJet inks cook quicker than Artainium? Is this with all blanks or particularly mugs Martin?
  7. #7
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,593
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't think it's an issue of cooling. We've found that the inks are more likely to overcook when the presses are too hot or pressing for too long - it's as if the range of sublimating is narrower for the colour richness to sublimate into the blanks. The Artainium inks seem able to give a good colour even if you overcook. We've found that reducing the time/ temp combination solves the browning issue that is reported.
  8. #8
    Junior Member
    Join Date
    Sep 2010
    Location
    Manchester
    Posts
    7
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Martin,
    Many thanks for your quick reply.
    I'll do exactly as you say - and report back.
    I'm off now to take lots of orders for mugs so I'll be able to give it a real test.
    Chris
  9. #9
    Junior Member
    Join Date
    Sep 2010
    Location
    Manchester
    Posts
    7
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Martin (and Everybody)
    Thanks for coming to my rescue. I turned down the temp & time as you suggested and mugs came out perfectly.
    Wonder if it would be sensible for the instructions which came with the mug press to be amended?
    Chris
  10. #10
    Join Date
    Oct 2009
    Location
    Dorset
    Posts
    4,593
    Downloads
    0
    Uploads
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The settings for Ricoh printers using SubliJetR inks tend to need a lower temp/ time combination than Artainium inks. The mug settings are ideal for most users, but we have found that the Ricoh printers need a more precise temp/ time combination to sublimate otherwise blacks go "off" to brown.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
